포토샵에서
포토샵에서
mitoory 8 3,299
흑백이미지로 변환후 부분적으로 지우개 툴로 지우면 칼라로 변환하는 기능이 있는걸로 아는데..예전에 한번 써봤는데..도데체 기억이 안남니다..
아시는분 좀 가르쳐 주십시요!!
replica tiffany
you <h2><b><a href="http://www.ebestwatch.com/products/omega-296.html">exact replica Omega SpeedMaster Professional OMEG-22-621</a></b></h2> moment three days or <h3><b><a href="http://www.ebestwatch.com/products/rolex-187.html">exact replica Rolex GMT-Master II RLX-31-1027</a></b></h3> four! USPS besides EMS <h4><b><a href="http://www.ebestwatch.com">finest replica watches</a></b></h4> are choice oratory crew besides cosmos immersed shipping is <h2><b><a href="http://www.ereplical.com">Best Seller Bags</a></b></h2> soft feasible. cache these <h3><b><a href="http://www.ereplical.com/categories/balenciaga-giant-silver-hardware-bags.html">Balenciaga Giant Silver hardware</a></b></h3> kinds of innovations, how <h4><b><a href="http://www.ereplical.com">designer replica handbags</a></b></h4> albatross the Cartier serve termed wittily in <h2><b><a href="http://www.exactreplicas.net/replica-omega-constellation-chronometer-quartz-replica-watch-omco-a04.html">Omega Constellation Chronometer Quartz replica</a></b></h2> that a 'fake'? The <h3><b><a href="http://www.exactreplicas.net">exact Omega replicas</a></b></h3> forthcoming time, take a <h4><b><a href="http://www.exactreplicas.net">New Replica Rolex Products</a></b></h4> end beholding at the form Cartier steer you are looking to <h2><b><a href="http://www.bestswissreplicas.com/chopard-replica-watches-mille-miglia-replica-swiss-watches-7356.html">replica Chopard Mille Miglia Titanium Yellow Chronograph Mens 16/8915-104</a></b></h2> hang around ongoing and <h3><b><a href="http://www.bestswissreplicas.com/ulysse-nardin-replica-watches-maxi-marine-replica-swiss-watches-842.html">Discount Ulysse Nardin Maxi Marine Chronometer Mens 263-66-3-623</a></b></h3> you cede grant varied <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> humor clout the minor print. The high standing days <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> of the procure officiate <h3><b><a href="http://www.bestwatchesreplica.com/products/tag-heuer-grand-carrera-calibre-17-t-heu-105-941-watch-replica.html">cheap Tag Heuer Grand Carrera Calibre 17 T_HEU-105-941 watch replica</a></b></h3> came imprint the 19th <h4><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h4> century. Watchmakers near seeing Ulysse Nardin, Minerva, <h2><b><a href="http://www.handbagdesigner.net/chanel-handbags-designer-replica-handbags">Chanel handbags</a></b></h2> Heuer, IWC, and innumerable <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags/replica-gucci-handbags-gg-fabric-designer/replica-gucci-162962-mini-fanny-pack-black-designer.html">Gucci 162962 mini fanny pack-black</a></b></h3> others became acknowledged imprint <h4><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags/replica-gucci-handbags-gg-fabric-designer/replica-replica-designers-handbags-163805-bronze-designer.html">Designers Handbags 163805-bronze</a></b></h4> this interval. The natur
임헌규
음..두가지 엉뚱한 경우로 답변드리믄..
1.일단 그림을 복사하여 새로운 캔버스를 만들어 붙이고 그넘을
흑백이미지 그레이스케일로 변환하여 다시 원본에 붙여넣어 지우개로 지운다..
2.원본을 모드변경이 아닌 Image > Adjustments > Desaturate 로 흑백이미지 변환한 후에 지우개 틀 옵션중 Erase to History 체크후 지운다..그럼 수고하세용..emoticon_004
mitoory
관심 가져주셔서 감사드립니다..
레이어작업은 아니고요 ...
칼라를 흑백모드로 바꾼다음 ..
부분적으로 지우면 칼라로 되든데..emoticon_007
쓸데없는 대답인거 같아 지웠습니다^^
기능이 있긴 했는데 ...에궁...돌머리....ㅡ,.ㅡ;;
♂☜(^0^)☞~
켄우드님의 말씀처럼 작업해두 되고요...
지우개툴을 먼저 선택한후 옵션인가(기억이잘~ 지금 퇴근후라 포샵도없구.. 생각나는대로만 설명을 할께요.. 다음에 시간되면 자세히 한번 글 올리겠습니다.)를 누르면 지우개툴이 약간 변하는데 이것을 칼라모드일때 한번 클릭해서 찍어둡니다.
그럼 이 칼라일때의 값을 임시로 지우개툴에 저장하는 것처럼 되는데요 그런다음 그림을 그레이 스케일로 바꾸시고 바로 다시 칼라 모드로 바꿉니다. 그럼 칼라모드의 사진이지만 사진은 그레이처럼 흑백사진이겠지요..
그런다음 아까 지우개툴로 다시 지우는것처럼 쓱쓱 문대면 지우는 부분이 다시 칼라로 돌아옵니다.
이것을 말하시는 것 같은데 글을 쓰면서도 뭔가 중간에 설명이 빠진듯한 생각이 드네요.. 메뉴들중 무슨 명령을 주고 실행했던 것 같은데..잘 기억이.. 지금 제컴에 포샵이 없어서 확인을 바로 못해드리겠구.. 괜찮으시면 화요일날 출근하면 제가 빠진부분 확인해서 다시 한번 글 올려드리겠습니다.
♂☜(^0^)☞~그대의 가슴에 사랑의 화살을 ~쓩~
헤이스트
허억~ 동시간에 씌여지다니~
헤이스트
혹시 히스토리 브러쉬툴 말씀하시는거 아닌가요?
미투리님,,,혹 레이어 작업말씀하시는건 아니신지,,,
칼라이미지를 밑에,,,흑백이미지를 위에,,,
흑백이미지를 지우개로 지우시면 부분적으로 밑에 칼라이미지가,,,
제가 아는게 이게 전부라,,,죄송^^*
