질문입니다. 플러그인 관련 고수님께 부탁드립니다.
선녀
웹관련
8,026
2006.03.30 14:03
사파리에서요,,
MIME 유형 “application/x-oleobject”의 내용을 가지고 있습니다. 이 MIME 유형에 대한 플러그인이 설치되지 않았기 때문에 이 내용은 보여지지 않습니다.
라는 경고창이 뜨는데요,
어떻게 대처해야 하는지 상세히좀.... 부탁드립니다.
replica tiffany
2010.04.07 11:32
replica watches <h2><b><a href="
http://www.ebestwatch.com"
>replica watches</a></b></h2> on display too, and <h3><b><a href="
http://www.ebestwatch.com/products/rolex-199.html"
>Rolex Air-King RLX-18-1058 imitation</a></b></h3> you will see watches <h4><b><a href="
>exact replica rolex</a></b></h4> of all types ? designer diamond encrusted watches, all <h2><b><a href="
http://www.ereplical.com/products/thomas-wylde-barolo-to-die-for-ii-clutch-in-red-71127-06-4767-bags.html"
>Thomas Wylde Barolo To Die For II Clutch in Red 71127-06-4767</a></b></h2> metal classy watches, chronographs <h3><b><a href="
http://www.ereplical.com"
>replica handbag</a></b></h3> that are not run <h4><b><a href="
>replica handbags</a></b></h4> of the mill, and uniquely designed watches that <h2><b><a href="
http://www.exactreplicas.net"
>replica watches</a></b></h2> defy all the rules. <h3><b><a href="
>replica watches</a></b></h3> Especially in the last <h4><b><a href="
http://www.exactreplicas.net/replica-tag-heuer-replica-carrera-watch-tacar-a06.html"
>Tag Heuer Carrera</a></b></h4> category of watches that defy all the rules, IWC replica <h2><b><a href="
http://www.bestswissreplicas.com/breitling-replica-watches-windrider-replica-swiss-watches-1095.html"
>Breitling Windrider Chrono Cockpit 18kt Yellow Gold Steel Turquoise Mens B1335812-C6-489 watch</a></b></h2> watches rule the roost. <h3><b><a href="
http://www.bestswissreplicas.com"
>replica watches</a></b></h3> All of the modern <h4><b><a href="
>swiss replica watches</a></b></h4> replica watches launched by the company come with some <h2><b><a href="
http://www.bestwatchesreplica.com"
>best watches replica</a></b></h2> kind of a unique <h3><b><a href="
http://www.bestwatchesreplica.com/products/speedmaster-chronograph-omeg-75-672-watch-replica.html"
>cheap SpeedMaster Chronograph OMEG-75-672 watch replica</a></b></h3> deployment. Take a look <h4><b><a href="
>watches replica</a></b></h4> at the replica IWC Pilot (
http://www.watchcopiez.com/GoodsSeries/Pilot-248.html)
series <h2><b><a href="
http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags"
>Mulberry handbags</a></b></h2> and you will find <h3><b><a href="
http://www.handbagdesigner.net/loewe-handbags-designer-replica-handbags"
>Loewe replica handbag</a></b></h3> some of the most <h4><b><a href="
http://www.handbagdesigner.net/new-dior-handbags-designer-replica-handbags"
>NEW Dior replica handbags</a></b></h4> unique replica watches on t
replica watches <h2><b><a href="http://www.ebestwatch.com">replica watches</a></b></h2> on display too, and <h3><b><a href="http://www.ebestwatch.com/products/rolex-199.html">Rolex Air-King RLX-18-1058 imitation</a></b></h3> you will see watches <h4><b><a href="http://www.ebestwatch.com">exact replica rolex</a></b></h4> of all types ? designer diamond encrusted watches, all <h2><b><a href="http://www.ereplical.com/products/thomas-wylde-barolo-to-die-for-ii-clutch-in-red-71127-06-4767-bags.html">Thomas Wylde Barolo To Die For II Clutch in Red 71127-06-4767</a></b></h2> metal classy watches, chronographs <h3><b><a href="http://www.ereplical.com">replica handbag</a></b></h3> that are not run <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> of the mill, and uniquely designed watches that <h2><b><a href="http://www.exactreplicas.net">replica watches</a></b></h2> defy all the rules. <h3><b><a href="http://www.exactreplicas.net">replica watches</a></b></h3> Especially in the last <h4><b><a href="http://www.exactreplicas.net/replica-tag-heuer-replica-carrera-watch-tacar-a06.html">Tag Heuer Carrera</a></b></h4> category of watches that defy all the rules, IWC replica <h2><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-windrider-replica-swiss-watches-1095.html">Breitling Windrider Chrono Cockpit 18kt Yellow Gold Steel Turquoise Mens B1335812-C6-489 watch</a></b></h2> watches rule the roost. <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> All of the modern <h4><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h4> replica watches launched by the company come with some <h2><b><a href="http://www.bestwatchesreplica.com">best watches replica</a></b></h2> kind of a unique <h3><b><a href="http://www.bestwatchesreplica.com/products/speedmaster-chronograph-omeg-75-672-watch-replica.html">cheap SpeedMaster Chronograph OMEG-75-672 watch replica</a></b></h3> deployment. Take a look <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> at the replica IWC Pilot (http://www.watchcopiez.com/GoodsSeries/Pilot-248.html) series <h2><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags">Mulberry handbags</a></b></h2> and you will find <h3><b><a href="http://www.handbagdesigner.net/loewe-handbags-designer-replica-handbags">Loewe replica handbag</a></b></h3> some of the most <h4><b><a href="http://www.handbagdesigner.net/new-dior-handbags-designer-replica-handbags">NEW Dior replica handbags</a></b></h4> unique replica watches on t
2006.03.30 15:06
일단 MIME에 대한 개념과 그 적용 방법 등에 대해 순서를 아시는 것이 중요할 듯합니다.
개념이 정립이 되면 상황에 맞추어 적절한 MIME 설정을 해주기가 수월할 것이기 때문입니다.
그럼 제가 익스플로러의 MIME 설정에 대하여 정리를 해놓은 것이 있으니 참조를 하시기 바라며, 지금 이용하고자 하는 대상의 포맷에 적합한 MIME 설정 및 응용 프로그램의 설치를 통해 해결을 시도해 보시기 바랍니다.
http://www.iplace.co.kr/bbs/zboard.php?id=hoon&page=1&sn1=&divpage=1&category=6&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=172
크게 MIME 설정과 Helpers의 설정이 있으니 참고를 하시기 바랍니다.
안녕하세요? 박노훈입니다. 일단 MIME에 대한 개념과 그 적용 방법 등에 대해 순서를 아시는 것이 중요할 듯합니다. 개념이 정립이 되면 상황에 맞추어 적절한 MIME 설정을 해주기가 수월할 것이기 때문입니다. 그럼 제가 익스플로러의 MIME 설정에 대하여 정리를 해놓은 것이 있으니 참조를 하시기 바라며, 지금 이용하고자 하는 대상의 포맷에 적합한 MIME 설정 및 응용 프로그램의 설치를 통해 해결을 시도해 보시기 바랍니다. http://www.iplace.co.kr/bbs/zboard.php?id=hoon&page=1&sn1=&divpage=1&category=6&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=172 크게 MIME 설정과 Helpers의 설정이 있으니 참고를 하시기 바랍니다. 감사합니다.
